Old 06-15-2008, 07:18 PM   #192 (permalink)
1GCRXHF
HF - '85 Honda CRX HF
Just finished reading the thread with enthusiasm...
Just picked up my third 1G, an 85 HF with 102,000 on it. Good to hear the foam/FG works so well, I was planning on using it to replace broken panels for the door panels and rockers (mold straight to the door instead of making a new piece to attach).
I am most likely going to try and make a one piece nose for it as my header panel is garbage. What did you use to mount to the old header panel holes? I'd basically like to pull off the bumper cover (not reinforcement) and use the bumper mounting holes and the header panel mounting holes as my attachment points to the nose.
Some of my thought I didn't see...
There's no way to turn off the fuel pump, its mechanical and driven off a lobe on the cam. I frequently in my other CRX's would just kill the motor, set the key back to ON, and coast down hills, then popped it back into 5th (or whatever was needed) at the bottom and away I go.
The Fleet
FOR SALE: 1985 Civic DX Hatch - Fresh paint, rebuilt trans, Weber 32/36 carb
"The HF" :1985 CRX HF - 102K miles! Runs super strong, modifications will be entirely mileage oriented
"The DX" :1987 CRX DX - Devacced, excellent interior, runs perfect, the fun car
