Old 06-15-2008, 05:52 PM   #191 (permalink)
Blue - '77 Chevy P/U
Originally Posted by Chris D. View Post
expansion foam is the new duct tape
NO NO ,,,,they just work well together
Old 06-15-2008, 06:18 PM   #192 (permalink)
HF - '85 Honda CRX HF
Just finished reading the thread with enthusiasm...
Just picked up my third 1G, an 85 HF with 102,000 on it. Good to hear the foam/FG works so well, I was planning on using it to replace broken panels for the door panels and rockers (mold straight to the door instead of making a new piece to attach).
I am most likely going to try and make a one piece nose for it as my header panel is garbage. What did you use to mount to the old header panel holes? I'd basically like to pull off the bumper cover (not reinforcement) and use the bumper mounting holes and the header panel mounting holes as my attachment points to the nose.
Some of my thought I didn't see...
There's no way to turn off the fuel pump, its mechanical and driven off a lobe on the cam. I frequently in my other CRX's would just kill the motor, set the key back to ON, and coast down hills, then popped it back into 5th (or whatever was needed) at the bottom and away I go.
The Fleet
FOR SALE: 1985 Civic DX Hatch - Fresh paint, rebuilt trans, Weber 32/36 carb
"The HF" :1985 CRX HF - 102K miles! Runs super strong, modifications will be entirely mileage oriented
"The DX" :1987 CRX DX - Devacced, excellent interior, runs perfect, the fun car
Old 06-15-2008, 11:35 PM   #193 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
well progress today was the one of the nasty messy days..
Fiberglassed all the foam panels including the underside.. the rear end is soe soling donw you can push the car around from any of these panels.. wind tested it up to 85mph with no problems
Now to finish those c-pillars get them glassed up and mount a the new rear glass.. .. the car is now drivable so in a week or so I should get a half tank of fuel through it well see is whats there now is actually making a difference.
Old 06-15-2008, 11:37 PM   #194 (permalink)
Veggiedynamics
The nose is attached to some bolts int he radiator supports on the top and on the sides of the bumper wrap.. i kept the entire front bumpers under there incase i get crap from the "authorities" aka goon squad.. i can then say its meats all crash test standards for its year of production.. and I added saftly crumple zoned front and rear
Old 06-15-2008, 11:38 PM   #195 (permalink)
Veggiedynamics
Yeah it is, its better than bondo its super light weight..
Old 06-16-2008, 12:35 AM   #196 (permalink)
Green Machine - '92 Geo Metro XF i
Last 3: 42.66 mpg (US)
Black Ball - '99 Ford Contour SE V6 Auto
Red Baron - '96 Honda Civic HX
All jokes aside, I still have one of these CRX's an SI. I love that car. And what you're doing here is awesome.
Old 06-16-2008, 12:56 AM   #197 (permalink)
Originally Posted by ebacherville View Post
tested it up to 75mph already without the rear quarters on .. all stayed there just fine, realize its all fiberglassed over when done
Well then I'm buying!
Old 06-16-2008, 07:55 PM   #198 (permalink)
Veggiedynamics
well drove the CRX to work today.. the weather was windy and road construction really hampers my ability to get nice stretches of highway...
I did get my scan gauge today.. so i did some testing on that with our 2 odbII vehicals and i seem to be on the right track for driving with vacume vs on a digital gauge.. I need to figure out my MPH 5 diffrence as i have over sized tires on the pickup.. there 235-75r15" vs the stock 215-70-15" makes the spedo off by about 4-5 mph..
Old 06-16-2008, 08:23 PM   #199 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
I love this thread Exactly what I want to do to the AXe.... one day!
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 06-16-2008, 10:27 PM   #200 (permalink)
Veggiedynamics
well I got the tire size calculated and in the truck.. seems i can sustain 30mpg at 55mph pretty easy... considering the 24 rating by the epa thats a pretty decent rating.. maybe the coloroado will be next on my list for areo mods.. areo topper and a 3" lowering..
First I'll finish the CRX however
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
