Originally Posted by type2teach
I also monitor the battery amps and that is within the range of normal. The amps even increase as I step on the accelerator, but the van refuses to move.
This line stood out to me... so, you're saying the controller is drawing power from the batteries but the van isn't moving? Or, is the van moving but not accelerating?
If it's drawing power, I'd say the controller is working and the problem is elsewhere...
I had a problem when I pulled my motor to balance it. When i put it back in, one of the balance washers extended too far past the flywheel radius and jammed into the bell housing and seized everything up. but, my car wouldn't even roll.
perhaps you can clarify that line a bit?
