Well sorry for the wait ...
Here are the unofficial results of my *******ized Acetone test:
Tank prior to Acetone; 20mpg
Tank w/ Acetone; 23mpg
Tank after, no Acetone; 17mpg
So say what you will the car got better mileage with acetone and had a withdrawal after it was spent ...
I will continue to use it religiously until the engine falls apart. Then I will conclude its bad for the engine .. LOL
1oz per 10 gallon, thats all you need ... Check my log for accurate numbers
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
