Old 01-15-2013, 03:35 PM   #103 (permalink)
MD2000
Master Modifier
MD2000's Avatar
I do not have a service manual to check if it is the same wire as the 2005 and lower civics, or if it works the same?
The signal is called DC/DC inhibit, so if you can dig up a schematic that would be the best way to proceed.
The 2006 Civic has the dual subpacks with two 6 cell sticks joined with a welded on buss bar. I would expect that one could make up a copper bus bar and screw it on the end of the more readily available 6 cell sticks.
I believe Bumblebee batteries will sell you individual used 6 cell sticks that have been tested.
Good luck
Mike Dabrowski
http://www.99mpg.com/
