Old 01-17-2013, 05:13 PM   #28 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
Originally Posted by mcrews View Post
Most alloy wheels DO NOT have a lip to attach the hub cap to.
So you would have to use steel.
No you have a (probably) heavier rim with all the inertia issues......
You could presumably fix that problem by using a set of wheels with solid snap on wheel covers then just affix the pans or Mooneyes onto the plastic wheel cover.
The GenII Prius has fairly light (14.5?lbs) 15x6 wheels with a tight snap cover as do the GenIII wheels although they are heavier at 16.25lbs.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
