Old 01-21-2013, 11:48 PM   #151 (permalink)
RatherDashing
Originally Posted by Rusty94cx View Post
I wouldnt worry about the injectors. I believe that all the injectors are the same. You could pull the rail and watch the spray pattern. I think your chasing ghosts though. Yes I'll double check but I'm sure I'm turning like 2100 at 65. You have just a dx lx trans in there it could even be a ex/si big bearing trans. I also have 175/70 13 tires and steel wheels on there so you know. There was a vx in a junkyard in Cinci not sure if they still had the trans. It was on craigslist. You can see I'm getting 42 with a shot 02 check engine light on no lean burn.
Dang something is definitely slowing down my mpgs :/
Im hoping i can find one somewhere in indiana.if not hopefully get one shipped for a descent price.makes sence.next time im driving and goin that fast ill double check. but its going to be hard since its been snowing pretty hard lately.
It looks like im only getting around 30mpgs.only other things i can think of is maybe cat is clogged or maf is bad
