Old 01-22-2013, 08:54 AM   #43 (permalink)
justme1969
justme1969's Avatar
Well Im still working on that issueI think I would like to kill the injectors across the rail.
I also want a start button. The reason is to install a remote start or shut off is no less important.
My car is a front wheel drive with a clutched 5 speed.
The 3 things I see coming is; #1 excess wear on clutch from jump starting on the roll.
#2 excess wear on motor mounts being front drive.
#3 excess wear on key and ignition switch.
So im still in work on this having a bit of trouble finding a harness diagram that shows what and where. Start is really simple catch it pre neutral safety switch.
I may just catch shut down injectors in bottom side of fuse box but prefer to find a print and get it it harness instead.
