Old 01-22-2013, 07:43 PM   #109 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I was driving home today, and got a reminder that there are ALREADY commercially-available diesel-electric plug-in hybrid trucks that I see nearly every day!
The local school bus company owns 14 hybrid busses. Here's one I took a photo of at a traffic light.
The best part is that they solar-charge them! The car port that they park under has a giant grid-tie PV array that nets out to how much power the busses use through the year. I believe the bus is THIS ONE, in case you are interested.
I also dug through my box of misc EV components and found that DC/DC converter. It's rated at 15 amps at 12V, and has an output voltage adjustment, so I should be able to turn it up into "12V battery charging range".
It's a brick that's about 8 x 2.5 x 4 inches and will run on 110-330VDC
I think 180 watts should be enough for a truck DC/DC converter. Regular headlamps are usually 55 watts each. Taillights and radio can't take much power. I'm not sure how many watts the heater blower runs, but if I was in EV mode anyways (and thus using the DC/DC instead of the alternator) I'd probably just be using a seat heater.
There's always the possibility of converting to HID or LED headlights as well, which should also lower the 12V power load.
I guess technically, this is just a power supply, but it can run on either AC or DC.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following User Says Thank You to bennelson For This Useful Post:
mikeyjd (06-11-2013)
