Old 01-22-2013, 08:18 PM   #2 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Is it possible the source used is fuse. Use a multimeter to check if there is still have 12V coming to the meter and the ground is still good. A 12V light bulb can be used to test if you don't have a test meter, just place it across the two leads. The odds that the gauge has an easily replaceable fuse are slim, if it's digital it may have a solder in component used as a fuse on a circuit board. It can be tiny, usual the first device on the positive, sometimes negative side. Good Luck.
