Old 01-23-2013, 03:59 AM   #50 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Potenza View Post
To the OP: Just wondering if you have any updates concerning your 8-valve modification. I was thinking of doing something similar, but I have two questions.
1. Where did you find the spacers for the missing rocker arms? I can't seem to find them on any HF parts catalog.
2. Are there any issues with fuel buildup behind the inoperative intake valve? Upon researching, it looks like the VTEC-E setup actually opens the 2nd intake valve a very small amount just for the purpose of keeping fuel from pooling on the valve.
Thanks for any info!
The spacers are shown here:
http://www.hondaautomotiveparts.com/...E+-+ROCKER+ARM
#8 and #9 in the diagram. It's a little confusing since Honda strangely included 16 rockers in the HF diagram.
Looks like they might not be available anymore. I got mine from a junkyard. The 1992-1995 CX should have them as well. Or find a pipe with the same inside diameter as the rocker shaft diameter and make your own!
If there's fuel building up behind the valves, I haven't noticed it. I've got something like 5000-6000 miles on it like this, no issues. But you'll never see the top half of your tachometer again!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Christ (01-25-2013)
