Thread: #10!
Old 01-24-2013, 09:07 AM   #12 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by 320touring View Post
Mine is a TD (no I) its an indirect injection turbo with no intercooler as standard- pretty much the same spec as your engine, although I think you may be 10-15bhp more than me (my AAZ is 75bhp/110Ft/lb torque)
Based on your fuel log, I think I'll aim for 65 imperial MPG
to start with, then see if I can catch you up!
I'm sure 65 MPG Imp won't be any problem if you'll drive carefully. Tell me do you have fully mechanical FI pump or "fly by wire" like my TDS? If you have mechanical pump it will be tricky to install any FE monitoring device if you have FBW with potentiometer gas pedal you should be able to connect MPGuino without any issue, like I did in Berta. And that's amazing how much you can save if you have real time FE monitoring.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
