Old 01-27-2013, 06:15 PM   #156 (permalink)
RatherDashing
Originally Posted by Rusty94cx View Post
I would guess plugged cat by the one pic with 02 out heck at 75 in 4th gear it's 3000rpm. Yes 2000-2100 5th get 65 2500 at 75. I would say trans is biggest mpg hog. Then check cat. Use vacuum gauge. Heck see if it run better with the 02 unbolted.
My last cheap attempt at this hesitation issue is going to go thru this tank of gas.
Then try techon? Whatever its called.injector cleaner on high grade shell vpower gas full tank.
Either that or the MAP sensor.hesitation stopped after fuel filter came back after seafoam cleaning.seafoam must have chunked sumthing up.
Wud it hurt to try another seafoam treatment thru vac line and gas tank even tho i just did it?
Maybe its sooo dirty it needs it again idk
Going to try to test the map sensor the best i can since its stripped on there at the moment.take out injectors when i have time.really savn up to find thr right vx trans for the right price and get a clutch as well since im down there
