Old 01-27-2013, 09:31 PM   #23 (permalink)
dohcsvt
Rodney - '00 Plymouth Neon Base
90 day: 33.05 mpg (US)
Tojo - '99 Honda Civic LX
90 day: 34.99 mpg (US)
Sorry to dig up a 4 month old post!
NoD~ ,
I have a 2000 neon, which I know is a different body style than yours. I Currently have tapped into the blue wire from the ignition switch which still kills the dash. I was hoping to find a way to kill the engine without killing the dash. I was thinking of tying into the voltage to the coil pack or the fuel injectors. THEN...I stumbled across this post. I have since begun researching this ASD and am a bit confused. All the wiring diagrams I can find show 2 red/wht wires into teh ASD and a dark blu/yel and dk grn/org out of it. The dk blu/yel is the relay control voltage, but I see no ground wire in any of the diagrams. So, my question is if I splice my switch into the dk blu/yel wire this should work ...correct? Also, where did you locate the wire you tied into, under the dash or in the engine compartment? Any help would be appreciated.
Ottis
2000 Neon.
My first attempt at good fuel economy
Have had MANY F-A-S-T gas guzzlers in the past
Goal is 47 MPG
