Old 01-29-2013, 05:14 PM   #26 (permalink)
darcane
darcane's Avatar
Originally Posted by sendler View Post
The examples with the pick up trucks is a bit of a trick question. If you knew the gear ratios (as he did on the CBR250R forum) and multiplied through from the engine torque you would see that at that moment the rear wheel torque would be the same in all three gears even though the gears are different and the rpms are different.
And from the acceleration chart I can see that I got sidetracked and that acceleration will be increased with increasing rear wheel torque even though that rear wheel torque will average higher when shifting either side of the power peak of the engine. Not the torque peak of the engine.
I hadn't gotten to that question, but yes, if the horsepower is "flat", then acceleration will be the same regardless of which gear you are in.
That said, it is quite unusual to have a flat horsepower curve for a large enough rpm range to span multiple gears at the same speed.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
