Old 01-30-2013, 11:26 AM   #3 (permalink)
Mugg
Coal - '97 Honda Civic HX
Found the thread!
Below is the thread and the response from Meelis...
ecomodder DOT com/forum/showthread.php/mpguino-20362-2.html#post341628
Hi,
I personally have not seen a point to add bigger screen - you see 4 values in one screen and you just flip between screens to see other values.
If this larger screen has standard 16 pin interface on top of it, then it probably works, but it needs code changes to put 8 values to one screen.
The Following User Says Thank You to Mugg For This Useful Post:
stargazerf3a (01-30-2013)
