So it looks like the CR-Z has that same 4.29 final drive. It also has a half-gear taller 6th gear. The entire transmission won't swap because there's an IMA motor in between the engine and transmission. I'm wondering three things. 1. Will the final drive swap over? 2. Will the 6th gear work as a replacement 5th? 3. Where do you acquire such parts???!!
Oh, and the other basic question: $$$
