Old 01-31-2013, 06:37 PM   #27 (permalink)
bondo
bondo's Avatar
Originally Posted by plasticuser View Post
Today things are really taking shape. I'm getting the luan on, getting beautiful curves...
Once that's on, I'll just very lightly bondo the seams and sand to get a professional looking finish, then seal it all in...
One thing I can't find... The mystical auxilliary brake light lead for hooking up the brake lights on camper shells. Where do they stash that?
The wire you are looking for is located under the drivers side door in the wiring harness against the frame. It will be a green wire with a black cap on it. Snip off the black cap and that is your hot lead for the brake light.
You will have to wire up a ground wire to the frame or another good grounding location also.
Best of luck to you on your project, it is looking very good.
Bondo
The Following User Says Thank You to bondo For This Useful Post:
plasticuser (02-01-2013)
