Originally Posted by plasticuser
Once that's on, I'll just very lightly bondo the seams and sand to get a professional looking finish, then seal it all in...
Make sure you use Bondo Gold, its what I use on cabinets when there going to be lacquer finish. I thinly coat the entire surface and then lightly sand. The finish paint is so smooth you cant tell its wood.
Normal Bondo is to much work
