Old 02-01-2013, 10:48 AM   #32 (permalink)
plasticuser
Annette - '04 Ford F150 FX4
Penelope - '08 Mazda CX-7 Sport
90 day: 23.47 mpg (US)
Originally Posted by GeekForLife View Post
Make sure you use Bondo Gold, its what I use on cabinets when there going to be lacquer finish. I thinly coat the entire surface and then lightly sand. The finish paint is so smooth you cant tell its wood.
Normal Bondo is to much work
Good advice, which I will take. A little extra expense is worth it. I've used regular bondo in some car restorations and it is time-consuming to get the perfect results...
