Old 01-28-2013, 09:59 PM   #21 (permalink)
Annette - '04 Ford F150 FX4
Penelope - '08 Mazda CX-7 Sport
90 day: 23.47 mpg (US)
Plans to A-B-A test the cap when it's finished?
Absolutely. I also plan to video the ABA tests and have anyone local along to observe/report. And tuft test.
If you get sick of that cold weather up there, feel free to come down and help
Old 01-28-2013, 10:02 PM   #22 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Ha! Well, I've been hiding from the cold weather on the Wet Coast this year. But if you're still working on it next winter ...
Old 01-28-2013, 10:02 PM   #23 (permalink)
I bought the hardware, and a cheap, sacrificial tarp from Harbor Freight yesterday. I'll put the frame together with the hardware, then cut up the cheap tarp (which has a convenient small amount of stretch) and use them as a temporary cover for the panels. That way I can do some preliminary tuft testing and ABA testing before committing to the curve and design.
Let's see if we can make some big progress tomorrow
The Following User Says Thank You to plasticuser For This Useful Post:
aerohead (01-29-2013)
Old 01-29-2013, 06:59 PM   #24 (permalink)
Progress...
Today I put the sides in. The design has become a lot more rigid now there are triangles involved. This is good.
Next, I assembled the lid and dry fitted it with the retaining clips. It's a bit more snug than I'd like, but it looks right.
I attached some photos of today's work.
ID:	12375   Click image for larger version
ID:	12376   Click image for larger version
ID:	12377   Click image for larger version
The Following 3 Users Say Thank You to plasticuser For This Useful Post:
aerohead (01-31-2013), BamZipPow (01-29-2013), GeekForLife (01-30-2013)
Old 01-31-2013, 07:05 AM   #25 (permalink)
90 day: 19.36 mpg (US)
Originally Posted by plasticuser View Post
That's a nice Airstream you have there. Single axle at that length, is it a 50's pre-torsion axle one?
The one pictured is an '83 Silver Streak an upmarket cousin to Airstream. I've now a '90 model (different in appearance). Leaf sprung suspension . . for now.
Old 01-31-2013, 03:21 PM   #26 (permalink)
Moving swiftly on...
Today things are really taking shape. I'm getting the luan on, getting beautiful curves...
Once that's on, I'll just very lightly bondo the seams and sand to get a professional looking finish, then seal it all in...
One thing I can't find... The mystical auxilliary brake light lead for hooking up the brake lights on camper shells. Where do they stash that?
ID:	12389   Click image for larger version
BamZipPow (02-01-2013)
Old 01-31-2013, 05:37 PM   #27 (permalink)
bondo's Avatar
The wire you are looking for is located under the drivers side door in the wiring harness against the frame. It will be a green wire with a black cap on it. Snip off the black cap and that is your hot lead for the brake light.
You will have to wire up a ground wire to the frame or another good grounding location also.
Best of luck to you on your project, it is looking very good.
Bondo
The Following User Says Thank You to bondo For This Useful Post:
plasticuser (02-01-2013)
Old 01-31-2013, 08:02 PM   #28 (permalink)
Bondo
Found it! Wow, they really hid that well. It was tucked behind a wiring harness, behind a plastic cover. Including the 3/4" black cap, I'd say there's about 1" of wire there. I guess I'll carefully remove the cap instead of snipping it off, so I have something to work with
What do you think of my rounded tail, Bondo? I'm trying to keep the airflow attached to 18" behind the truck. I will make a rounded section to fit beneath the tail, so guide and smooth out the airflow coming up from beneath -since we all know turbulent air is a bad thing.
My luan laying went fairly well. On the one side, I applied it in 3" strips and it took the compound curve very well. On the other side I got brave and put it on as one piece. Not so good. I'll take it off tomorrow and make another piece in 3" strips, and start bondoing... Is bondoing a word? I also need to put a couple of guide strips under the top of the tail piece. It has tried to dip down and I suspect it will cause the air to break away right there.
Old 02-01-2013, 07:42 AM   #29 (permalink)
bondo's Avatar
It would be best to ask aerohead about the rounded back end. A boat tail extension may be best that mounts on the lowered tailgate. That will get you another 24" back and then you can also haul 4x8 sheets of plywood laid flat in a 6.5 foot truck bed and keep the wood dry too.
Bondo
Name:	new win. quarter view - box.jpg
The Following 2 Users Say Thank You to bondo For This Useful Post:
CargoBoatTails (08-18-2014), plasticuser (02-01-2013)
Old 02-01-2013, 09:25 AM   #30 (permalink)
GeekForLife's Avatar
White Elephant - '07 Toyota Tundra SR5
90 day: 19.27 mpg (US)
Raberta RX - '14 Lexus RX350 Base
Make sure you use Bondo Gold, its what I use on cabinets when there going to be lacquer finish. I thinly coat the entire surface and then lightly sand. The finish paint is so smooth you cant tell its wood.
Normal Bondo is to much work
The Following User Says Thank You to GeekForLife For This Useful Post:
aerocap, f150
