Old 02-01-2013, 09:01 PM   #22 (permalink)
HilseeJ
TBA - '07 Honda Fit
Well, well, well. It appears that I now understand what I need to do. However, I still have a few questions. But first, let's start with the materials list.
* denotes a question involving the item
(1) Momentary Switch, Normally Open
(2) 5 pole relay - Bosch 30 Amp
(3) Inline fuse holder - 20 Amp
(4) 15 Amp Fuse (for holder) *
(5) 16 gauge wire
(6) Ring Spade for Ground *
(7) Male and female spade connectors *
(8) Are there any other materials I am missing? (I already have solder and a soldering gun)
Questions:
Do the above items look right? Are there any items I am missing / don't need / got the wrong amperage on?
Regarding item (4):
Is 15 amps the right number? According to this diagram, the wire appears to be 15 Amp. Is that correct?
Regarding item (6):
How exactly does one find a ground? I never understood this in grade school, and to this day I am still confused.
Regarding item (7):
I was thinking of putting spade connectors in when I splice into the wire. That way, if something goes wrong, I can just unplug the relay and slip the two ends of the injector signal wire back into place.
Would this work or am I missing something?
WeatherSpotter had some complicated circuit board that I didn't really understand.
Again, thanks for all the help and thoughts fellas. I am grateful.
And my apologies to Mr. 3-Wheeler. Your car is awesome. I wish I knew how to make that aeromod, and make it look that sexy.
