Old 02-02-2013, 12:16 PM   #2 (permalink)
wmjinman
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Well, technically, a belly pan is an aero mod. If you're willing to do that, why not a "stealth" grille block?
Are you willing to use "driving techniques"? Because that can probably overwhelm any extreme engine work (driving "bad" can give you worse mileage than driving "good" with a stock engine, while driving "good" can give you better mileage with a stock engine than driving "bad" with all the engine mods possible)
For example, I've hit or exceeded 50 mpg on the highway twice with an un-modified FOUR cylinder '99 Suzuki Swift (the bigger, heavier model).
The Following User Says Thank You to wmjinman For This Useful Post:
Davo53209@yahoo.com (02-02-2013)
