Old 02-02-2013, 12:51 PM   #4 (permalink)
Davo53209@yahoo.com
Originally Posted by wmjinman View Post
Well, technically, a belly pan is an aero mod. If you're willing to do that, why not a "stealth" grille block?
Are you willing to use "driving techniques"? Because that can probably overwhelm any extreme engine work (driving "bad" can give you worse mileage than driving "good" with a stock engine, while driving "good" can give you better mileage with a stock engine than driving "bad" with all the engine mods possible)
For example, I've hit or exceeded 50 mpg on the highway twice with an un-modified FOUR cylinder '99 Suzuki Swift (the bigger, heavier model).
Yes you are certainly right in saying that a belly pan is technically an aero-mod. Instead, what I was trying to say was that I'd rather not do anything that radically changes the appearance of the vehicle. A grille block is another good suggestion, and as for driving techniques, you may be please to know that I do that already.
