Please prove how 40lb of removal would be a 'surprise' ?
maybe you should read some more before you question Niel's answer........
and imho, there isnt 40 lb of material in the average car sold in england.
secong, if you are dismantling the interior to find '40lbs' why not put the new isulation back on the interior? you are just creating a tin can with insulation on the outside.....there is a reason they put the sound deadening material on the inside.
And how will this insulation on the outside react to water.......?
