Old 02-04-2013, 05:02 PM   #107 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Yea. If you can't get it out might be worth a phone call to a shop to see if they'd just get that bolt out. When you heat it make sure you heat the body of the alternator and also the bracket where the bolt slides through. Be carful with the pb blaster too it might light up. Good luck
