Old 02-04-2013, 04:01 PM   #101 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Yeah wish it were a CX
Thanks. It's just that the lower through-bolt is stuck inside the alt and I can't get it out or move it independent of the alt. Of course it has that wacky 24mm square head...
I'm going to try pulling the alt bracket off when I get in there. Can't figure out what else to do. Ideas?
Old 02-04-2013, 04:11 PM   #102 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I don't know about the air dam. I'm not used to mods on your car that don't get seen before the actual car.
Transmission type Efficiency
Old 02-04-2013, 04:13 PM   #103 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
On my d15 I have laying here you can't get the bracket off unless the alternator is out. :/
I know exactly which bolt you mean. I'm assuming the nut is off. Try spraying wd40 or pb blaster on the bolt and let it soak a little. Thread the nut onto the bolt slightly (3 or 4 threads) and try and tap it loose with a small hammer. Don't go crazy if you hit too hard you could damage the threads on the nut. Could also try using a screwdriver or chisel on the big square and and try prying it through
Old 02-04-2013, 04:18 PM   #104 (permalink)
Sven7's Avatar
Huh?
Yeah I was hoping I could slowly work the bolts out as I pull the bracket away from the block... there really is no good way to do it.
I tried tapping the bolt after the nut came off and buggered up the threads. Now the nut won't go back on. Tried putting vice grips on the thread ends and tried turning the bolt with a box end wrench. It's been sprayed with PB Blaster several times in the past few weeks. I think the bolt has rusted so much in there that it's not going to move. There's no room to get a saw in there and chop the bolt off- I'd end up cutting into the bracket or ruining the much-needed $50 core.
I have the brand new OEM replacements just sitting on the bench, too.
Taking it into the local shop is an option, but I'd rather not spend the money. However, I'd also rather not mess around with this thing in the cold and have to drive the parents' Yukon.
Old 02-04-2013, 04:31 PM   #105 (permalink)
laying on the ground stinks. i looked up the labor time on our shop system, it calls for 1.3 hours. thats without tax or if they have to spend extra time on the rusty bolt. would save over a hundred bux if you could get it out yourself. if you have a torch handy that might do the trick. laying on the ground sucks though. could try taking the tire off and getting a long punch or screwdriver on that bolt and give it a few good heavy wacks.
The Following User Says Thank You to slownugly For This Useful Post:
Sven7 (02-04-2013)
Old 02-04-2013, 04:52 PM   #106 (permalink)
Sven7's Avatar
Good suggestions. The ground isn't so bad right now... I'll try the torch and a punch.
Figured the shop rate would be up there. Wish I could pay them $50 to just get it out... I could drive it home and do the rest. :/
Old 02-04-2013, 05:02 PM   #107 (permalink)
Yea. If you can't get it out might be worth a phone call to a shop to see if they'd just get that bolt out. When you heat it make sure you heat the body of the alternator and also the bracket where the bolt slides through. Be carful with the pb blaster too it might light up. Good luck
Old 02-04-2013, 05:18 PM   #108 (permalink)
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
You can try the magic mixture of 50% pure Acetone and 50% ATF.
This can melt plastic so you should mix it in a glass or metal jar. Shake up and apply with an eye dropper. don't breath the fumes. Give the casing a whack if you can. It should loosen the bolt in 15 min.
Old 02-04-2013, 07:45 PM   #109 (permalink)
Sven7's Avatar
Haha, I don't know if I even have access to acetone or ATF without buying some new. Probably rather have a shop do it than mix up cancer juice
Old 02-06-2013, 10:36 AM   #110 (permalink)
Sven7's Avatar
Shop wants over $200 to just replace the rusty bolt. $135 an hour. They do great work but... I think I'll find a less expensive option.
Got a full-time job offer at GM a couple days ago so I need to get this Civic ready to drive back to Detroit! (In a few months all three of my cars should be there, getting the help they deserve)
I don't want to jump the gun... but if things are going well in 6 months I might think about buying an EV.
