Originally Posted by serialk11r
Problem is 1ZZs exclusively came with 5 speed transmissions (horrendous garbage) in the US, while 2ZZs exclusively have 6 speed transmissions.
The 2ZZ has MMC liners, and exotic something else, and is a capable engine across the whole rev range, in fact I wouldn't be surprised if it were more efficient across the board (maybe except at very low rpm) due to the friction reduction measures.
One other notable 2ZZ feature as compared to the 1ZZ is an 11.5:1 compression ratio instead of the 10:1.
Also the Lift Cam doesn’t engage on the 2ZZ until roughly 6200 RPM, so for >99% of all driving it isn’t helping or hurting you.
