I get the "point"
...er, not to use it anyway.
Thats why I came here, Im a newbie in the aero world, and appreciate the advice. The sharp front end was inspired by the old Lamborgini Countach...which of course, has a very sharp nose...I was thinking they had some good aero designs on board to acheive 200 mph...but then too, 500 hp helps too.
I am planning a frontend mod that will slide in like a reciever hitch as opposed to mods being screwed on. Instead of plugging up front end vents and adding spoilers, I was thinking an additional (now bubble shaped instead of sharp
) frontend cap that can be removed easily by pulling a pin. It will be started off with just styrofoam, then depending on outcome, go to fiberglass or something similar.
