Old 02-08-2013, 11:22 PM   #14 (permalink)
88FieroGT
I have some plastic parts coming in that should be easily able to make a working small scale prototype , or atleast a proof on concept model.
always nice to find parts for under 10 bucks that will work and not break the bank , little to no special manufacturing and techniques needed to produce most of the components.
I will try to have video results , pictures , data if im able to without giving away too much
ive also found some cheap sprag clutches on ebay , one in particular that seems interesting 1.85OD , 0.79ID , and 0.55WIDE/thick all in inches converted from mm , that supposeably can handle 29ft/lb of torque and weights only .11 of a gram IF the specs are correct , unsure of the rpm capability but might be a clutch I will end up using for the proof of concept model. Based on this , and the pdf document I am pretty confident it can hold up with the right setup.
