Originally Posted by orbywan
So this photo brings up an interesting question. Should I ever have time to finish the damn thing, when I arrive at the final shape of my boat tail I intend to have an A&P friend of mine cover it in aluminum. So it will be similar to this awesome creation in the photo.
The question is this; you've aluminum skin over a steel frame. How do you keep dissimilar metal corrosion at a minimum or eliminate it?
Your A&P friend will know to use zinc chromate primer between the aluminum and the steel.
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
