Originally Posted by Davinator61
Hey JellyBeanDriver, I'd like to order an MPGuino from your DSchmidt Technologies site in the near future (
No worries. I'll be here.
As far as using a hall effect signal, that will be fine. If it's only a raw AC waveform, that could be problematic.
In regards to pulse/min for speed, you can use the default settings (my Geo Metro's setting) and drive a known distance, figure out the difference and adjust the counts accordingly. Even if you start with the 'correct' values, one should always perform a distance and MPG calibration as even the same make and model can can be different with different fuel blends and different gearing/tires.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
http://www.dschmidt.com/MPGuinoJBD.html
