Old 02-12-2013, 11:47 AM   #122 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Yea that commute is killing it plus the really cold weather. Around 1000-1200 is when I see it. Anything lower and the injectors start working. Also since installing my afr gauge I've noticed dfco doesn't work as well when it's cold. It requires a higher rpm maybe 1500 so i drop to a lower gear
The Following User Says Thank You to slownugly For This Useful Post:
Sven7 (02-12-2013)
