So plan still is to replace the transmission. But now im wondering when i shud replace it.theres a big hole in the exhaust on resonator pipe b.car is quite loud at the moment.the pipe online is about 100$. The leak is after the o2 sensor and cat converter but wud it still cause my hesitation at cruising speed/light acceleration studdering?
My mpg is dropping lower and lower.one of the fuel injectors has black residue on the outside.
Ran seafoam thru the air system again a week ago still no change.
This problem only occurs after warm up tho.drives fine when cold.
Im hoping its not the cat converter and maybe the map sensor.
Just wondering what routes i shud take first need some opinions.
Is taking the cat converter out hard?
Just the fact that im losing mpg and tranny still grinding not sure what i shud tackle
Trans from syncrotech is 750 with shipping and core exchange.
