Originally Posted by mluckham
I haven't worked on this for quite awhile, but here is the version I am using - it does have the feature you want, I think.
I don't know about the clock crystal, probably it will work fine.
Mike
Thank you very much ! I'll try it right now...
If you use a 20Mhz then to avoid any problems i will just hook up one when i am going to built the simplified mpguino board.
Thank you! Hail Canada
Also to add this version (0.82) can not be compiled with latest IDE But version (0.81) can , just to help other users
