Originally Posted by razor02097
I'm curious how you can find out about using a turn signal and how would they know where a stop sign is by raw data in a black box? Even if the GPS has a black box... lets say..... the best GPS is still 3 yards or more off.
My
2005 Magnum uses CAN bus data to actuate the turn signals. That can very easily be stored inside a mandatory black box. Steering wheel turn rates and position are also turned into CAN data, which can also be easily be stored in a mandatory black box. This isn't fevered imaginings from some tin-foil nutter, dude. This is from the factory service manual.
I'm sorry but speeding is not probable cause for a search. They still need consent, a warrant or they need to arrest you. All those "illegal searches" you hear about are usually from someone that inadvertently gave the officer consent to search.
So you're a cop, now, huh? Tell me, then, why should you be easily allowed to get all this information?
