Its after the 02 and after the cat converter in resonator pipe b.i cud get a new pipe for 100. Just not sure if thats it.but def made a difference.my worry now is the stripped bolt for the water outlet.i put a new gasket in it cuz the old one was soo worn away.i broke one of the bolts that holds it in right in half.so its leaking coolant. Going to order a new gasket and have the shop get the broken bolt part out.
