Originally Posted by Rusty94cx
Drill and tap go slow. Patience. If the leak is that far away then it's not the problem.
I dont think i have a drill for doing it.shop does it for me cheap plus i get a discount them from my work place since were partnered with them.ill probably have them fix the stripped bolt on the throttle body for the map sensor.hesitation is still bad after warm up while cruising. If its not from the hole in the exhaust/ map sensor/ or fuel injectors idk what it is.
