Old 02-17-2013, 08:15 PM   #109 (permalink)
tony_2018
I'm very interested in how this would work on v-tec-e engines. So far I only heard that Marvel Mystery Oil does the trick to help get lean burn mode in better so that you can get better gas mileage. I already started using that and keeping records of gas mileage and even checked my tires as well, 40psi. Was getting around 33mpg on an auto, 40psi tires, kept the throttle very lightly but in order for me to gauge that I will need a vac gauge. But for now all I can do is keep the speed consistent, same rpm at all times, NO CRUISE CONTROL as this will rev/lower the rpms during inclines/declines.
