Thread
would you get better mpg......... (unhook the cruise control vacuum line?)
02-19-2013, 12:40 AM
2
permalink
H-Man
The brake pedal is evil
Denny's Detector
- '08 Mercury Grand Marquis
Taserface
- '17 Chevy Volt
Not really. CC isn't on normally. Normally unhooking a vacuum line causes the engine to run lean unless an oxygen sensor is in the system, most cars built in the past 30 years will have an oxygen sensor. Leave the CC hooked up but don't use it.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
H-Man
View Public Profile
Send a private message to H-Man
Find More Posts by H-Man
