Old 02-19-2013, 12:28 AM   #1 (permalink)
master modder
brent777's Avatar
ticker - '97 nissan d21 xe
Pickups
90 day: 27.06 mpg (US)
Send a message via Yahoo to brent777
would you get better mpg......... (unhook the cruise control vacuum line?)
would you get better mpg if you unhooked the vacuum line to the cruise control?
-its hard to have a fun life if you don't have fun in life-
Old 02-19-2013, 12:40 AM   #2 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Not really. CC isn't on normally. Normally unhooking a vacuum line causes the engine to run lean unless an oxygen sensor is in the system, most cars built in the past 30 years will have an oxygen sensor. Leave the CC hooked up but don't use it.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 02-19-2013, 12:44 AM   #3 (permalink)
master modder
brent777's Avatar
Pickups
good point what about unhooking it and plugging up where the line was?
Old 02-19-2013, 01:34 AM   #4 (permalink)
Nope.
Old 02-19-2013, 01:35 AM   #5 (permalink)
Jenny - '02 Chevrolet Prizm Lsi
90 day: 31.45 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 25.27 mpg (US)
Unhooking it and plugging it will only help mileage if there's an existing vacuum leak in the system. Basically, if your cc system is leak free it already acts as a plugged vacuum line until you use it. And even then, if you do use it, your car will lose vacuum pressure for about half a second as it is set and then it acts as a plugged vacuum line again
Old 02-19-2013, 09:42 AM   #6 (permalink)
master modder
brent777's Avatar
Pickups
oh okay got ya
