Old 02-19-2013, 01:47 PM   #10 (permalink)
oil pan 4
When I put a turbo on my diesel I picked up at least 2 to 3 mpg on the highway. And thats compairing driving 55-60 when N/A to +65MPH w/turbo.
Diesel engines are nice because the more air you can cram into the cylinders the better the fuel econony and power out put will be.
If you had a boost gauge you may see why there is a fuel economy jump at the higher speeds. At 60 the turbo maybe under such light load it may not be kicking out any boost, at 65 you could be developing 1 or 3 PSI and that small change can make a lot of difference.
Originally Posted by Varn View Post
Trying to find a way to get more boost at less speed.
Water injection
