02-18-2013, 06:07 PM
Do more with less
Run 60 get 28, run 65 get 30, run 70 get 29.
Mercedes 3.0 TD
Seems like the turbo diesel boost helps more than the aero hurts. My sample size is small but am going to continue driving 65 in my Mercedes for more data. I think I am comparing similar driving conditions. The engine is supposed to have peak torque at 2000 and 65 mph is 2800.
The car supposedly has a cd of .4 and is fairly small. yet pretty heavy for it's size. The engine is strictly old school IDI TD, no computer.
Comments?
"A man is not finished when he is defeated. He is finished when he quits."
Richard M. Nixon
"The reward of suffering is experience."
Harry S. Truman
“There's no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.”
Ayn Rand
02-18-2013, 08:10 PM
Master Ecomadman
MPG should be inversely proportional to MPH.
- Tony
02-18-2013, 08:12 PM
Don't buy it. Maybe if it had taller gearing. Keep us posted as you get more data.
02-18-2013, 08:33 PM
Should probably include data points for 50 and 55.
02-18-2013, 10:04 PM
Tell us how you did your testing.
The vacuum gauge plus wheel covers helped increase summer 2015 mileage to 38.5 MPG, while summer 2016 mileage was 38.6 MPG without the wheel covers. Drove 33,021 miles 2016-2018 at 35.00 MPG.
02-18-2013, 10:24 PM
Do more with less
Tony I won't argue as to the theory. But I drove it for 3000 miles at 55.
My VW gets better mileage at 55 (55 mpg). It gets only 2-3 psi at 60. The Merc gets 5 psi at 60 and 8-9 at 65. Trying to find a way to get more boost at less speed.
Richard M. Nixon
Harry S. Truman
Ayn Rand
02-18-2013, 10:29 PM
Drop a gear?
02-18-2013, 10:33 PM
Do more with less
Nicky It is a 4 speed auto and 27 years old. Everything above 30 is in top gear. You might be right.
Richard M. Nixon
Harry S. Truman
Ayn Rand
02-19-2013, 07:12 AM
#9 (permalink)
If everything above thirty is in top gear, then thirty five is probably where you can get best economy.
Of course, that's problematic on US highways where going thirty is just as good as standing still...
02-19-2013, 02:47 PM
#10 (permalink)
EV convert
When I put a turbo on my diesel I picked up at least 2 to 3 mpg on the highway. And thats compairing driving 55-60 when N/A to +65MPH w/turbo.
Diesel engines are nice because the more air you can cram into the cylinders the better the fuel econony and power out put will be.
If you had a boost gauge you may see why there is a fuel economy jump at the higher speeds. At 60 the turbo maybe under such light load it may not be kicking out any boost, at 65 you could be developing 1 or 3 PSI and that small change can make a lot of difference.
Water injection
