Old 02-22-2013, 12:26 PM   #13 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Geo trackers weren't meant to tow. Doesn't mean people don't but since these vehicles weigh a little over 2000 lbs towing would be iffy...
There have been people that swap out the 5 speed diffs for the diffs found in the autos in order to get the revs down but quickly realized that 5th gear became almost useless. These little engines just don't have the torque to be playing with gears like that.
Also you aren't suppose to use 4WD on pavement for a reason. Binding up the driveline is the fastest way to break something. Yes it is possible to drive on pavement in 4WD but Use it only at low speeds...you have to be extremely careful and not to turn the wheel much. Also when you turn the wheel you need to let the driveline tell you how much you can.. Feel the wheel go back and forth by itself you will know what I mean. Forcing it will bind it up. If you have to make a sharp turn you need to pop it back in to 2WD. Before I had my NP242 T case with 4WD full time in my Jeep I used to have the NP231 and used 4WD part time during nasty winter days since the added traction was necessary... I did the above and luckily didn't break anything.
Project Avalon: E bike build
