Old 02-22-2013, 05:23 PM   #180 (permalink)
RatherDashing
the hole in the exhaust was getting way to annoyingly loud. got the pipe b resonator from cat to muffler for 100 on ebay. had to get a new muffler since the one on it was the wrong one. only 40 bucks for the oem muffler at a local shop. not bad at all. runs MUCH quieter now.
Also while I had a few hours before work i still looked at what else i could do to figure out the issue. I know it could be the cat but i need to get a decent car jack. the one i have is pretty much going bad.
recleaned out the egr valve curious to know if its supposed to be pretty hard pressure to move it up and down. new one is quite expensive but i really dont think thats the issue thats just outa of curiosity.
one of my buddies said to take the fuel rail out and check the fuel injectors. i did just that and the injector tips themselves wernt too bad. but LOTS of black gunky crud on inside of injector areas where they are inserted to the engine. I know theres a technical term for that area but dang it was bad. had to get new o rings for the injectors. sad news is in order to clean the gunk out i had to take the ones out 2 of them snapped one fell into engine bay sumwhere.also a fuel pipe insulator fell down in there too. but had to clean that gunk out did it the best i could. fuel injectors still looked good didnt look cracked. had to go get the o ring kits for them since i cudnt just get ea o ring individualy so taht was about 40 bucks.
going to re hook it all back up tommrow put all the seals back on full tank of gas with techron and see if maybe this was the case.
i tried my best with the map sensor but im going to have to take it to a shop to get it off. its stripped on there good. my drill bits are dull. i figure might as well get it on there since iv had the replacement sitting around
AND if thats all not the case i shall definitely try and remove the pipe underneath the cat converter to take a good look. from the top after i replaced the exhaust manifold gasket which was very bad. the cat converter looked clean. none of the filter areas was clogged. i shook it a little too and didnt hear anything rattling around like the bad one in the previous crx.
all in all its coming a long. im holding off on the new transmission from syncrotech since the hesitation problem has been getting pretty bad and milage dropping as well
heres a pic of what the dirty area looked like. i know its not from mine but mine looked like those if not worse in all 4 of them
http://i60.photobucket.com/albums/h2...elInjector.jpg
