Originally Posted by Old Tele man
Water vapor is LIGHTER than air, that's why clouds are UP in the sky, not on the ground. It is also why bad (cloudy & rainy) weather is associated with LOW atmospheric pressure (high water vapor in air) and good (clear & dry) weather is associated with HIGH atmospheric pressure (low water vapor in the air).
Right
But how does fog LP area help my truck or most other gas CE run better/smoother?
