Hey guys,
I am in need of help , the only source on my car that i could take some speed signal is the abs sensor which gives an voltage reading of 0.5V to 1V every time i spin the wheel slowly and 0,7V when it turns faster (i assume that is a average reading) i've removed the 50k resistor that mpguino requires for a 12v signal and nothing happens it just don't measure vss at all... What kind o signal mpguino expect to read? and also in what creteria do i configure the ms delays for inj. and vss signals?
I have 0.82 canadian version
*I'll add a 1n4148 diode hopefully it will work...
