Old 02-12-2013, 12:33 PM   #411 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Originally Posted by AndrzejM View Post
There's a metric option in v0.86 code or you can use "Canadian" metric v0.81 code.
If you want to calibrate US version you just need to use conversion factors that you may find here: Fuel economy conversions / calculator - EcoModder.com
I've chose metric at the setup menu but that still exist.
I'll maybe try canadian version , which one do you prefer?
Old 02-13-2013, 04:01 AM   #412 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
For now I'm using v0.81 "Canadian" code http://ecomodder.com/forum/showthrea...tml#post202348
Because of bug that exists in v0.86 mentioned here:
http://ecomodder.com/forum/showthrea...ugs-23930.html
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
stargazerf3a (02-13-2013)
Old 02-14-2013, 05:59 AM   #413 (permalink)
Thank you! it is so much better for metric use but no instant L/100Km as i can see that is what i am used with
Old 02-14-2013, 06:14 AM   #414 (permalink)
AndrzejM's Avatar
There are km/l and l/100km instant values on the "Custom screen". I'm used to l/100km as well but you'll find that measuring FE in km/l is much more accurate and it's very easy to get used to it.
Old 02-14-2013, 07:52 AM   #415 (permalink)
No doubd about that , i will just have to get used to it i suppose...
But would be nice though to have another big instant for l/100km
Old 02-15-2013, 08:49 AM   #416 (permalink)
MPGuino Order
Hey JBD, just ordered one of your MPGuino builds & PMed you about it. I also thanked you on this thread, as a token of my appreciation. Again, thanks for the device in advance.
Old 02-21-2013, 08:11 PM   #417 (permalink)
Just received my MPGuino from JellyBeanDriver (DSchmidt Technologies) and am glad to see it's a relatively small unit...shouldn't be too hard to find the right sized enclosure for it...I'll post when I've got it hooked up and running...later.
Old 02-24-2013, 12:04 PM   #418 (permalink)
Got my MPGuino hooked up and tested yesterday...calibration's almost fine-tuned to the right settings...seems to be working like a charm...thanks JBD for a VERY professionally put-together circuit-board-and-display combo...now only time will tell as to how worthwhile my investment in this system REALLY has been.
Old 02-25-2013, 04:10 AM   #419 (permalink)
Hey jbd may I order a mpguino from you? Please pm me
Old 02-25-2013, 08:08 AM   #420 (permalink)
Hey guys,
I am in need of help , the only source on my car that i could take some speed signal is the abs sensor which gives an voltage reading of 0.5V to 1V every time i spin the wheel slowly and 0,7V when it turns faster (i assume that is a average reading) i've removed the 50k resistor that mpguino requires for a 12v signal and nothing happens it just don't measure vss at all... What kind o signal mpguino expect to read? and also in what creteria do i configure the ms delays for inj. and vss signals?
I have 0.82 canadian version
*I'll add a 1n4148 diode hopefully it will work...
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
For Sale Preassembled MPGUINO NEW $45. randall OpenGauge / MPGuino FE computer 1 10-24-2009 04:13 PM
MPGuino, Preassembled BRAND NEW Sean T. For Sale 4 10-22-2009 07:00 PM
Brand New MPGuino Preassembled Sean T. For Sale 1 06-17-2009 01:02 AM
