Old 02-27-2013, 11:45 PM   #7 (permalink)
wmjinman
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Sorry if I seem to be "stalking" you, Mike. HAH!! I just tried to get a better (bigger) view of your truck and ended up finding this other thread you started.
Just this morning I was reading a couple of threads on here about air intakes, "free flowing" filters, etc. Seems the jist of it is that the throttle valve is the #1 restriction, and unless you're running "wide open", any other percieved "restrictions" in the intake path won't effect anything. If you were racing, and wanted better power (and possibly fuel economy for less pit stops, or whatever) while running "wide open", then "opening up" the intake might help. Otherwise, no benefit.
Similar deal with the exhaust; in the threads on exhaust, they're saying that unless there's excessive backpressure, you probably won't gain anything by a "free flowing" system either. - unless - - - same thing.... If you're looking for maximum power, usually at higher RPM (like in racing), then opening it up would help. Someone on here said you could remove a sensor in the exhaust system & put a sensitive pressure gauge in the hole, then check it while running. I can't remember the exact number, but it seems like it was something like 4 psi. If you've got less than 4 psi in the exhaust system, you're ok. But it might have been lower - maybe 1 or 2 psi - just can't remember.
But the "bottom line" is, unless there's something wrong with it (clogged cat. converter, pipe smashed shut, etc.) the factory exhaust system should be more than enough to flow the rates you need while hypermiling. Again, if you were racing, then it would be a different story.
As far as cams, yes, a less aggressive "RV" type grind may help. Although, since all the auto makers are required to meet minimum EPA mileage standards, their stock cams are probably pretty damn good already. If it was me, I'd probably want to do a fair amount of research before I got too carried away with replacing the factory cam to improve mileage. Someone on here who knows more than I do could probably advise better, though.
Electric fans - not sure. I've heard they help, but I've also heard that a properly operating clutch fan doesn't take any power either, so I'm not sure on that one. One thing I've often wondered about is, could a solar panel on the top of the vehicle add enough juice to your electrical system to reduce the load on the alternator enough to see a measurable improvement? With that shell you have, you've got the room for a much bigger panel than my litts Swift has. - but I dunno - maybe it's "unicorn" material.
A/C delete - well, just not turning it on "deletes" a lot of it. LOL. But of course, removing it saves the weight as well as the belt drag turning that pulley (even if the clutch to the unit is disengaged).
