I ordered a new distributor for bout 70 bucks.i took it off to check ignition coil and didnt have enough time. and put it back on.hesitation is even crazier.has to be from distributor. Lock nut remover is on its way this weekend.timing is off.facing the looking at it its more aligned with the black line not the red on in the middle.and i cant turn the distributor anymore to get it there
